Re: Project Never Ends
Thought I would update things as it has been awhile.
Few things have been added/installed. The main goal right now is to improve the 60ft times.
Right now if I can get a solid 10second time slip on 10psi of boost I will be leaving it like that for awhile. Time to just refine it, pull engine out, clean up things, repaint a few body panels and just generally make it nice.
Truck is an absolute blast to drive, just a few bugs left to work out but my to do list is getting shorter and shorter.
Major to do's left are
- MSD 6AL (thanks Dennis) (Hoping it keeps plugs lite a bit better)
- MSD 2 step (in order to launch the same way everytime)
- Rear Sway bar (Susp. Tech I had from before, bolted up well even with the 4 link, hoping this will hold the truck flat on the launch for more traction and better 60ft times)
- Adjustment of lower 4 link bar (mock-up -vs- actual ride height didn't match, so made a new location for the lower 4 link bar, theory shows it should make a big difference)
- Boost solenoids are installed, slowly going to up the boost to 10psi over the next few runs.
- PLX guage for the WB installed.
- More tuning of Code59, mostly idle but looks like will be adding some more fuel under boost also.
- Install roll bar
- Front sway bar (it is ready to install though)
- Redo stereo, subwoofer, amps.
- Repaint a few panels, cladding.
- Working on a new custom 8.5" 10 bolt rearend.
