Re: Sy 354 LQ9 Turbo still AWD is running
Thought I would update this thread. Took this pic yesterday on the way home from the track. traction was an issue. Only got three passes two were full 1/4 runs but an oil leak shut me down for the day.
Here is the slip from my second run. Not doing any kind of burnout or cleaning the tires off, just pull up and go exactly as i drove it there. 93 octane and about 10lbs max boost. Tried launching at 5lbs and it spun badly.
Oil "leak" i found out was just oil blowing out of the valley cover. Track official came down and found me (thought it was to tell me i was done because of going quicker than 11.5x without a roll bar) and told me i left a little puddle of oil at the starting line and should check out my truck. They were about done for the day anyway so I decided to call it a day.
I realized my one way valve i had put in the valve cover breather was not working and causing boost pressure to go in the valve cover
Ordered up a breather tank tonight. Hopefully i can put that on and get back to the track again before the end of the year. I really want a 10.xx slip before winter. On my last run i left with around 4lbs of boost and it had a 1.67 60' time, but was still spinning. It actually started to hop around just past 60ft and I had to peddle it killing that run.
I am pretty determined to get a 10.xx timeslip this season with the trucks current setup. I know these 7+ year old street tires arent helping but funds wont be around for some sticky ones till next year. I've ordered up a breather tank and should have my oil problem fixed this week so hopefully i will have one more update for this before winter!
