Re: Sy 354 LQ9 Turbo still AWD is running
Great build! Did you get the truck retuned yet?
I have been working on the tune some, it looks pretty good on the logs i've taken out on the street. (I do all the tuning myself). I hope to go to the local 1/4 mile tomorrow night if it doesnt rain on me to see if its working any better :tup:
That sounds AWESOME!!:lol: So, if i purchase the XFI/EFI kit from FAST (the crate/transplant engine kit) there shouldn't be anything else i have to buy from them? As far as having the same (tuning) set up that you have?
Thats pretty much what I got. You need all the sensors etc (I have a regular 3bar gm map sensor and just cut and changed the plug on the FAST harness). The transplant kit will have the can bus harnesses, the xim module for the coils, etc so you should be set. Its not cheap but their system is amazing and they just keep adding more functions.
I just ordered and received a couple days ago their boost control solenoid that the XFI can control based on speed and tps readings. Im really looking forward to getting that on there and set up. The new xfi has traction control, boost control, 4 stages of nitrous control, etc etc etc. I wont get the boost control on in time for the track tomorrow night but i want to see what the intake/tb and tuning have done before making any more changes.
I have my fans & both stages of the fuel pump controlled through the ecu as well. It has a bunch of auxilary analog outputs you can wire in yourself and set up based off coolant temp, speed, throttle position, map sensor reading, etc. You will spend weeks reading their documentation (which is very very useful it explains every single setting in the system). It is a lot to learn but its fun.
