0966Sy
Code what?
Re: Changes for 2012
Jegs/summit have the aluminum race radiators that fit inside the core support perfect. Not as wide as the stock radiator, but realy affordable. Run one of the upper hose cap adapter for ease of access for filling the radiator.
Hose cap adapter 34.95
http://www.summitracing.com/parts/SME-2202/
Griffin 3 core pro series radiator 269.95 will fit inside core support with little trimming for the radiator cap unseen from the topside. I wanted to go this way but couldnt because thats where my 3.5" IC is mounted. I am running the same radiator though.
http://www.summitracing.com/parts/GRI-1-55241-X/
I used aluminum 4" C channel to make a radiator support with universal poly mounts, turned out very well. If you have access to weld aluminum then making a couple brackets on the end tanks would be more suitable.
Goodluck! I like what way your going with this build and will be following closely
My plan is to stuff the radiator and e-fan as far into the core support as possible.
