Re: Changes for 2012
OK...done with the testing. Here is the last dyno sheet:
Reading the columns from left to right:
Corrected HP, Corrected TQ, Exhaust backpressure, Boost pressure, oil pressure.
Notes:
The backpressure gauge was reading consistently off by about 10#. The main boost gauge also reads about 2# off. This pull was logged through the Bigstuff3 at exactly 20#, and deviated less than 0.3# at any time. Exhaust backpressure looks to be at 1:1 @ 20# @ 6000rpm, which means this turbine wheel and back housing is absolutely up to the task with no issues.
I ran this combo without an intercooler. I ran (2) 15 gph nozzles post turbo for most of my testing, and added (1) 15gph pre turbo at the very end to test. If I kept the boost at 15#, the meth (100%) was able to drop the temps to around 90* by the end of the pull. Upping to 20#, I need more nozzle.
The 45mm wastegate was just not enough to hold boost down low like I wanted. I changed it to a Tial 60mm (waiting for my Precision 66mm to arrive) and had no issues at all.
I ran pump E85 (tested it at 82%) and 100% methanol in the kit (Alcohol Injection Systems - AIS).
I threw on that ugly heat blanket right before the turbo to see if it changed the readings any. It didnt make much of a difference. I got lazy and never took it off. I plan on sending the pipes out to be ceramic coated before installing in the truck.
I made around 35 pulls to gather more data. I learned a bit more of what E85 likes and doesnt. My plans are to run on the streets at 15#, and taking it to 20# if needed at the track.
