ChevelleDude71
Lo Boost
Well I though since I have the extra time I should set up a projects page for my syclone. I have been looking at these truck since my senior year of high school, but thought I would never be able to afford one, $12,000 to a high schooler is almost unthinkable. But this year when I saw my syclone for sale I knew I had to try, so I put my chevelle up for sale and it sold within a week. Valentines day and drove out to French camp that night to pick up my syclone ( I HAD a understanding girlfriend ). The car had been sitting outside for about a year before I got the truck so I have my work cut out for me. The plan is to get it to the point to where I can drive it reliably a couple times a week and it run low 12's maybe High 11's in the 1/4 mile. I'm trying to do this whole project on a budget because I have to start saving for a apartment soon, but I'm finding that to be a challenge :rotf: .
The truck was equipped with the whole Kenne Bell stage one, ( I took the chip out don't worry ) and came with a extra block, crank, 4bolt end caps, stock chip, mufflerless 3" exhaust with 3" cat, Blown piston rings and a million Black Widows. :rant:
So here is what I have done/have planned for the truck so far,
Wideband (LC-1)
Colbalt boost gauge
3 bar MAP/ also have a 2 bar
Walbro fuel pump
MSD distributor
MSD coil
Taylot wires
NGK spark plugs
New gas tank
RPM A2A
Vortech BOV
Flex a light mechanical fan.
B&M trans cooler
Battery relocation
All new engine sensors
deeper tranny pan with drain plug
catless 3" exhaust with borla XR1 muffler (off stock down pipe)
ABS delete
A/C delete
George Blakes front shaft
Upgraded steering shaft
Typhoon side mirrors
Beltech front and rear swaybars
Beltech drop springs (without overload springs)
Beltech 1" drop block
Set back plates
CBR Battle Bars
CBR Corvette brackets (not installed)
C5 Z06 front and rear brakes (also not installed)
C5 wagon wheels powder coated black
Turbo time front coil overs
Custom door panels (By Jerry Arendell)
RPM stage one turbo
I'm sure there is more I'm forgetting... oh ya and what ever weight loss I can find!
As for the engine....
Take out the stock block, install .030 over TRW forged pistons, L35 rods, comp 412 cam, 2.02 valves and minor port job by me. But other then that the engine will be stock.
here are some pictures of the truck.
the day I got it
I drove it like that...
the only rust!
here is a before and after of cleaning up the cladding
And here is after a couple bottles of Back to black
The motor in it's current state.
:myclone:
Wideband (LC-1)
Colbalt boost gauge
Walbro fuel pump
MSD distributor
MSD coil
Taylot wires
NGK spark plugs
New gas tank
RPM A2A
Vortech BOV
B&M trans cooler
Battery relocation
ABS delete
A/C delete
Set back plates
CBR Battle Bars
RPM stage one turbo
the day I got it
the only rust!
:myclone:
