Project Never Ends
Re: Project Never Ends
Yes, in the stock CAC location but tilted the opposite direction. Top is tucked in behind the bumper cover, bottom sits about the same height as the sway bar. Outlet is moved, waiting for material to redo the inlets. Long term would like to get an all new custom core built -vs- the ebay cores and a ton of trial and error on what I like.
I will try to get some pictures this weekend, with christmas break coming up should let me get some more progress done also.
blk00z28
Forced to by choice
Are you actually going to use those air filters in the pictures above? Will they provide you enough flow?
Probably not, they were cheap and kept dirt and debris out. Once I get everything else figured out I will be looking for something better.
Quick pic will post more later.
Ok been a little while since I updated.
Fenders are back on, truck has brakes now (which those that were at nats will appreciate). Built a custom fan shroud that tucks in tight to the radiator and the intercooler pipe, well forms around it.
Front is ready for alignment now, got a few things to tweak on the rear suspension and truck might be able to make a madden voyage around the block anyways under its own power.
Still a ton of little things left, but having a truck that drives will be a big step in the right direction. Brake system took awhile to get figured out and all the parts ordered. The only thing left from stock system is the mastercylinder. I switched out every line, flex line, etc and converted it all to -03 AN. Tossed the stock prop valve, installed an adjustable one, dual line locks, c5 from calipers, ls1 rear discs.
Once I can steal someones camera I will get some updated pics, and hopefully some video of the madden voyage.
Syclone0565
CustomMulticades.com
camera and camcorder charged up and ready to go :)
as long as I am the one running the camcorder :D
Six-is-Enough
Use to do a little Boost
Hell just give them to him, he's had your laptop for what a month now?:roll:
turbodig
Careful what you wish for... a Madden voyage.
ie, 'He turned the corner, and BOOM!'
Coolant system got filled up last night, as well as the anti-rattle clip I was missing for the brakes.
tonight plan is to get the vacuum lines hooked up, turn on the key and try and talk to the tranny computer and make sure it is loaded up for 4l80e. Once that is a go, no reason I can't fire it up and get at least the idle fuel dialed in close. The few times I ran it before it was real rich.
Some rear suspension mods and hopefully no later than tomorrow I can drive it around the block if for nothing more than to say it moved under its own power which will be a first time in ~5 years. :2thumbs: :cheers:
Here is how I bought the truck back in Sept. 1998
2fast4u
PUMPING THAT IRON!
Looks Crazy JS!! Nicely done.. Thats gonna kick some serious ass!! :tup:
Truck moved under it's own power today for the 1st time in over 5 years. WAHOO.
A few bugs to work out and truck isn't really DONE by any means, but drivable is a good start for sure.
The plugs were partially fouled from tuning, so a couple cylinders are not exactly happy. During the 3 drives around the block I could tell a few times those plugs actually lite off and WOW. Not sure my nut sack will be able to handle this.
Motivation to get all the little stuff done is high so be driving it to work in no time.
Daron
MikeRenz said:
i don't believe it w/o video
No kidding. I have been pressing Jeff for progress evidence with no luck. Need to look this thread up on Snopes.com...
Syclone0565
Here is a pic I took just a hour ago at Jeff's. We started on the exhaust manifolds on my sy today. :)
Daron
wow that is some good shit right there. I so want Jeffs wheels...
