Re: Project Executioner
Used a LS 6.0 truck engine I had sitting around today to mock up so I can make motor mounts and check for additional clearances. I used an off the shelf oil pan I ordered from Summit and the motor went right in. I did have to trim about 1/4" off the front diff torque tube mount on the passenger side that would touch the pan rail just a little, but you would have to do this with either pan if you want the engine to sit as low as possible. I have the engine mounted to my own custom made solid motor mounts and the pan sits about 1/4" up off the diff. I also mocked up a set of truck front serpentine accessories to see if the power steering pump would clear the steering box. It cleared by about 2 inches actually. I will not be running these accessories but just thought I would check so anyone else doing a LS 6.0 swap from a truck with all the accessories will know they will fit without issues. I am running a special serpentine setup made to also allow the Whipple belt to work and not interfere.
I did cut the A/C side panel open and will be fiber glassing it closed again as I will be running A/C with my 1500hp.
Here is the link to the summit pan
http://www.summitracing.com/parts/mil-31083
I also ordered a LS swap fabricated pan from RPM Motorsports and it was sitting right here beside the Mildon pan and I thought, Wow this looks just like the conversion pan, I took a few measurements and the Mildon pan has about 3/4" more clearance. The RPM pan does have a little kickout on the side of the sump area for a little more oil (About 1") I will get a pic over the weekend of the pans side by side.
