Found issue with truck being limited to 100mph. It was the MSD box. I normally shift around 4800 in 1st and 2nd, but when I hit 4900+ in 3rd gear at or near 100 mph, the truck would hit what felt like a soft touch rev limiter. I have the rev limit set to 6500 so that it never interferes, instead, we use Rob's setting of 5300 rev limit which he sets in the tune. I removed the MSD box and the truck went 110 MPH without even having to punch it. I had some previous issues with the box when tuning with Rob, so I had moved the ground to the frame and made sure to solder and heat shrink everything, but still ended up having to remove the box from the truck.
This is the third vehicle that I have had MSD problems with. The other two weren't even boxes. One was MSD coil packs and the other was a small MSD two step box. I think I am done buying their products. I'm sure they get a bad rap because a lot of people don't install their stuff right or don't get good connections. But, I remember all the circle track guys always running two MSD 6AL boxes with a toggle switch so that when one box failed, they could switch on the fly over to the other box and keep on racing. So, I won't have a two step anymore. I will just try racing without it. The good thing is that I still have my trans brake and the 3200 stall, so I should be able to build plenty of boost on launch.
Rob and I were getting ready to start adding Meth and working on the tune for that set up when Rob had worked some more of his wizardry and figured out a way to make the factory ECM run in closed loop with the 80 pound injectors and the BBK throttle body. We had previously had major idle issues in closed loop so we had been playing around with open loop stuff, which is a pain.
We are just about done with the street tune again. I know I keep saying that, but every time I change a part to fix any issues or any time Rob switches things up in the program we have to do some level of datalogging to straighten things out, it comes with the territory. Hind sight being what it is, I probably should have gone with a turbo tweak at the start of this thing but it has been fun to work with Rob on all this stuff. I have been learning from him along the way. He had to remote log into my computer the other day to fix a glitch in Tuner Pro, which ended up being a corrupt BIN.
The Texas summer has not been kind to us thus far. High IAT's are leaving some power on the table but a summer tune is always safer in winter than a winter tune in the summer. I've been able to make a full pull through all three gears with no knock on a 100 degree day, with IAT's starting at 115F and finishing at 155F. Boost was 15.5 (mind you, bigger turbo), timing was 12.8, and AFR's around 11.2. Fuel is 93 with Royal Purple octane boost added.
Once we start adding Meth, I will dial in more boost, and see if Rob wants to put more timing in the motor. I may wait till winter to put it on the dyno and see if Rob wants to get more aggressive with the tune when the air temps are lower.
I picked up top 40 at the Father's Day Car Show here in S.A., not bad out of 231 vehicles. There was some stiff competition, lots of trailer queens that I most certainly couldn't compete with.
Oh, and this last part is kinda funny. My girlfriend surprised me with a homemade cheesecake to celebrate the Sy's 30th birthday. June is the build month on my truck. She's a keeper for sure...both girls.
