Hey Sy2623,
We haven't started using the alky yet. But, we started maxing out the 50 pounders at around 15 pounds of boost on pump gas but keep in mind that is 15 pounds with a 62mm turbo so it's making more power than a stock set up. I'm running a th350 trans so the ECM isn't able to keep track of what gear I'm in, that particular system has been disabled in the tune.
I think timing is at 15 degrees right now. We should be able to get some more out of it with the new injectors before hitting the knock threshold, especially with the Royal Purple octane boost on top of 93 pump gas, we should be around 96 octane. The taller 1st gear won't allow as much timing out of the hole as a 700r4 but I can post back with what we are able to squeeze out of the truck before hitting knock and before using alky. My truck has been a little more knock prone than some of the other trucks on here which could be a limiting factor. Could be due to one of the following:
1. The engine has been noisy since I first bought the truck. I don't know the full history of the vehicle, I am finding new aftermarket parts the further I dig into this thing all the time. I have cut the oil filter open, didn't find anything. I also readjusted the lifter pre-load on the comp rockers, sound didn't changed though. Sounds like valvetrain noise. I may do some lifters in the future. This could be upsetting my knock sensor. I know the main bearings love to get hammered out on these things so hoping it's not that, but with all this datalogging and WOT operation the noise has never gotten any worse and I have great oil pressure.
2. The widebody injectors could have been rubbing. There is a GM TSB about widebody injectors making a knocking sound on Sy's and Ty's when the housings contacts the intake manifold. The pics of my injectors in the classifieds section would indicate that they were probably rubbing.
3.I have a torn driver's motor mount. I tried to run the engine torque limiter rod that everybody has but I couldn't use it. The previous owner cracked the alternator bracket and I epoxied it. It holds the alternator fine, but I don't trust it to hold the engine under load. So, I am running an old school chain from engine to frame on driver's side, I could be picking up some harmonics through this.
4. I have a 3" downpipe that is wrapped so it gets close to the frame as does the rest of the exhaust pipe all the way back, I gotta watch interference between the cross members and the pipe and readjust to make sure nothing hits anywhere.
Hope this helps bud!
