atkonkler
Is this your bush?
Re: Hmmm maybe this is why my boost is so low....
I should have checked this earlier. For those of you that still have catalytic convertors, there is an easy way to check if its gone bad. Aside from hitting it with a hammer...
Run the truck up to temp, use an IR thermometer and check the inlet and outlet of the cat. If the outlet isn't about a 100 degrees hotter than the inlet, it's bad.
In my case the inlet was 100 degrees hotter than the outlet.
And for us Californian's, Magnaflow makes a 50 state legal replacement.
I can't wait to get it back together and hit the
when any of your guys cats went bad ....how much boost was it building? And what kind of muffler did you go with when the cat clogged your muffler atomic?
