AppleTY
I should have checked this earlier. For those of you that still have catalytic convertors, there is an easy way to check if its gone bad. Aside from hitting it with a hammer...
Run the truck up to temp, use an IR thermometer and check the inlet and outlet of the cat. If the outlet isn't about a 100 degrees hotter than the inlet, it's bad.
In my case the inlet was 100 degrees hotter than the outlet.
And for us Californian's, Magnaflow makes a 50 state legal replacement.
I can't wait to get it back together and hit the DM's....
