Thanks. I'm pretty satisfied with how it turned out. It's not perfectly straight in some areas & I didn't plan some things out very well. I'm thinking I might make another one and use the things I learned from this one to make the next one better.Looks real good. Are you going to use flex tubing? What will hold the filter in place? I don't care what anyone says, that filter flows way better than the cones.
If you look under the truck there is already an opening that allows air to enter into the fender. Or I might add the TransAm vent like others have molded into the fender.Very nice ! How is it just pulling air from in the fender or are you going to vent it to the outside some how??
It's been holding up well since the manifolds & turbo have been sitting in the back of the Ty since I had them coated.bringing one back from the dead Rick how is the coating holding up on the manifolds and turbo? If its holding up where did you have it done at
Here's where I'm at after yesterday.
Installed March AC pulley cover, chrome receiver/drier bracket.
Removed PS/alt. bracket, radiator fan, intake manifold, rocker arms, pushrods & lifters. My intake gaskets looked to be OK, but I was surprised by the amount of oil betwen the gasket & the intake manifold. Maybe they were leaking around the lifter valley.
Cleaned up dirty inner fenders.
My To Do List:
Lifters, pushrods & rockers are going to be replaced along with some new valve guide seals.
Upper & lower intakes, & both front engine brackets are going out to be powdercoated.
Install Typhoon logo plate on upper intake.
Install some more chromed goodies.
Replace motor mounts.
Install Griffin radiator & SPAL fans.
Relocate map, coil & EGR solenoid.
Install new control arm bushings, ball joints, pitman arm, torsion bar mounts, then new tires.
I hope to get the motor mounts done today. It looks like the motor has been out before due to the pass. motor mount heat shield is installed wrong. Someone put the mount against the block first then put the shield on. looks like it's gonna be a bitch to get off. :rant:
where the hell did you get all those pulley covers? i cant find shit to fit mine :roll:
