Re: new front sway bar mounting system.....
Typically the ZQ8 is referred to as a 33mm bar. However 1mm difference isn't a huge order.
That play you speak of should be taken up by the end links, not that bolt. If that bolt is constantly twisting, it worries me even more about breakage. The wear between the bolt and the new bracket is amplified then.
Weld it on there, it won't bind. The endlinks will give enough to more than compensate for the difference.
