Re: X-cab Sy
So tell me more about your engine.. It appears to be a blow-through setup using Throttle Body Injection? If so what are you using for engine management? Are you increasing fuel pressure with boost? Did you have to do anything to seal up the throttle body unit so that boost would not leak out?
Very cool. I've always liked TBI and I think it usually gets a bad rap. Properly setup I bet it could work very well in a boosted application..
The truck & motor have 60k on the clock. Has run strong with edelbrock exhaust headers and solid crossover, free flow pipes, cold air intake & underpully set up. So This was a good candidate for a bolt on kit. The blower setup is 6-7 psi that with the direct shaft ( no internal belt/gears) and ceramic bearings, it runs very cool so no intercooler is needed. The TBI will give enough fuel being it can work on a 350. The TBI seems to be still tight, but if it does get blowthru, I'll send it off for new bushings. The stock chip is replaced with one designed for the blower and mods I've done. Any more mods and a different chip woulod be needed. I've done the TBI spacer, ceramic coated headers and crossover, electric fan, trans shift kit and cooler, MSD distributor and hot coil, 180 deg stat, Poly trans mount and torque strap that will keep things in place, hopefully. I didn't /can't now change the motor mounts for poly's. Heard of the melting issue and haven't seen the heat shields come out yet. I'm going to raise the rear 1" to give it a slight rake. With Chest Rockwell's help we got a pair of almost perfect Bravada leather seats, got to swap them out, Speedhut gauges with the needles painted to match the stock cluster. Going to paint the pod to match interior.
Hopefully, fuel won't reach $6 a gallon this summer, and I can get out & enjoy it soon.
