What did you do to your SY/TY today?
Status
Not open for further replies.
Gbodydriver
Re: What did you do to your SY/TY today?
I installed a three gauge pillar and a boost gauge for now. Im debating on what wideband to go with...
Washed her up a bit
Used it to haul my 1/5 scale around:D
ziembic
Pulled the trans and transfer case on the way to pulling the motor. Did it backwards due to waiting on a friend to borrow a hoist from.
qbnkiller
Conflaguration Specialist
...hear what? Are you saying my truck is loud? Must remember to turn up hearing aids...
SYCLONE#1531
'MOFOFAST
Finally pulled my transmision! Installing the 9.5 conv and a deeper pan. Wasnt as much of a big pain as I thought it was going to be! The only problem I ran into was the 2 top bolts on bellhousing! The driver side top bolt finally broke loose with a impact. I actually got a little worried on that one. Looks like the install should be pretty easy!
blacktyaffair
Drove the ty to Roswell to take my little wife to the doc. Wondered what the vibration could be. Tired of always working on it and thought maybe the vibration will "diagnose" itself when something comes apart and saves me the hassle of looking for the problem..Yeah, yeah. I know.
TNPhoon
1of28
Finally dragged my ass to Pull-A-Part and got some rear window hinges for $6.12.
Came home and after 20 minutes, no more gay wing!
On a related note: anyone need a rear wing?
SYO237
SyTy Registry
With the help of Harmon and Ian...
installed my trans, installed 60#s injectors, and now working on getting the truck to run good on code59.
NCTyphoonKid
93 Ty #1710
took the ty to a show today and won second lost by two votes.also got to cuss this guy with a pos falcon saying a bunch of bs about me and the ty because he didn't win anything.
DJ B
Checking out the new block, new tail lights, new turbo from bezerk, and the aluminum intercooler scoop.
should all be making a big difference now. We'll see in 600 MLS.
SYO237
SyTy Registry
Downloaded Datamaster now Im on the search for a ALDL cable.
Bought Tunerpro V5, got windows installed running on a virtual machine on my Macbook Pro so now I can finally tune with Code59 and not rely on other people's time/equipment.... only my ALDL cable has a bad USB port connection...blah.
You can buy new cables here: http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
or get the moates combo, which im told is superior (most moates products are anyhow): http://www.moates.net/aldu1-and-cabl1-xtremealdl-and-newcabl1-combo-p-127.html?cPath=64
Dr.Gixxer
Tucked some wires into the fender and painted some frame.
Quickstop [UK]
Combating adversyty.
What are you doing about AutoTune? Doesn't work with V5 TP RT I hear....
Big Mike
Well I started taking out all the burned up wiring, wet carpet and melted dash.
and wound up with this bucket of scrap wire
No it doesn't.
TP5 does have some nice histrogram features though that could be setup to do similar function.
Once you learn to tune autotune isn't really needed anyways, I wrote it to just give people confidence to get started.
vinnieTy
TY # 1889
Start a thread on the recreation of truck #????. Would love to see the progress. I also love the bucket of wires, DAM!! Best of luck. Wich i was closer i would help out. :D
IDRVSLO
When Hell Freezes Over
Not all today but in the last week,
-Wheels/Tires 18x11 and 18x9.5 Ace Slick 5 in chrome
-AEM Tru-Boost(Finally running stock boost again....no more 8.?lbs
-AEM Uego WB/O2
-Tinted the front two windows
This week: Installing pillar gauge pod, working to clean up wiring under the hood, get dash lights working and make my heater do more then nothing and heavy duty blow dryer settings...nice!
Status
