What did you do to your SY/TY today?
Status
Not open for further replies.
SEL777
One of 101
Re: What did you do to your SY/TY today?
Tried for the millionth time to get the purple wire on the AC blower nice and tight. This after it cut out again in the boiling hot sun! I still don't think I got it. :( Would hate to cut it and put a regular terminal but I might have to if it cuts out again.
I had an issue with my fan working intermittenly (sp?) and the dealer replaced the motor then the relay....lastly they cleaned the contacts on the HVAC controls and problem solved. Old partsin the garbage...yea they were bad. Take thetime to actually diagnose the problem.....assholes.
vinnieTy
TY # 1889
Made it look alittle bit more cleaner and nicer underneath. ALso painted my rear swaybar.
ziembic
Pulled the accessory bracket and down pipe last night. Tonight is the turbo, manifolds, AC and tensioner brackets and possibly the intake.
Rexxenexx
index.php
Cleaned the engine bay. The car has been outdoors ever since new. One day I'll remove the brackets and repaint them, but I did manage to strip and repaint the dipstick since the paint was cracking and falling off.
REVEREND HARMON
Party in a box!
Put in the new stall converter and douched tranny back in the sy. Put her back on the ground and backed her out of the garage.
Man she needs a bath and wax :D
SYCLONE#1531
'MOFOFAST
Got mine up in the air, pulling the tranny this weekend, might need to go a tad higher? installing a 9.5 2800 stall with balloning plates.http://revmaxconverters.com/torque-converters/performance-car Ill let everyone know how this convertor performs? I couldnt find any dirt on them anywhere . Ls f-body & diesel crowd seem to like them. I guess ill be the ginny pig for the SY/TY crowd. Oh well, I cant wait to beable to launch this thing again!! My stock conv sucks with my new turbo 2.5lbs max against the brakes.:rant:
Matt
Worked on friends syty's to fund the repair of mine :lol:
SYO237
SyTy Registry
Ordered some 60# injectors to replace the 50# injectors and braided line ABS delete kit from Hood to replace the original ABS delete kit from Hood.
aasltmike
Took her to the salvage yard to check out what they had there...last chance for me to stretch her legs today before I have to put her to bed for 2 months while I'm in school in VA. :(
bundie
picked up my welded turbo to IC pipe so i can install the blitz DD bov.
Converted the lights back to stock after some european light conversion....but **** it got my plates now hehe
denny
Did this..
and saw this...
Couldn't find a balancer puller, so couldn't get the crank off. Will do that tomorrow,.
Sean Krupa
Moderator
Took my Stock Turbo + Downpipe off in about an hour. Guna unshroud the wastegate puck for my JSM 3" DP which I'm getting back from the Coater Monday. Also installing my Solid Motor Mounts next week.
chevy110
i took off the hood bent the hinges back to the way theyre suppose to be strapped the hood down and went and passed an e test WOO:D
Quickstop [UK]
Combating adversyty.
bled all the brakes (again :( ) tried to get the wastegate to work properlyand then tried to bleed the intercooler system.
Turns out the hose connecting the intercooler to the throttle body was loose! Tightened it up and immediately felt the difference. Instant spool and 20 psi before I let off. Damn it's fast again!
Props to Big Mike and Sy 1193 for putting up with me all day! They're great to hang out with and really generous with their time.
fauXGT
Brick Pilot
Finish test fitting & wet sanding. Now need to find a painter... since mine is blowing me off.:squint:
Status
