Lastest Picture update
These pictures hopefully will illustrate what was done to make everything fit and work properly. Some of the photos might not be that interesting!
1. AMS-1000 mounted upright in the glove box
2. Shows the cross over pipe wrapped and the painting done on the brackets (some cleaning required still)
3. Same as above, but missing the lower heat exchanger...lots of room here
4. Underneath the front of the motor missing the lower heat exchanger, you can see a little bit of the intercooler
5. Driver side exhaust manifold (blurry, but really tight to take pictures)
6. Fuel filter and fuel charcoal canister located underneath the bed.
7. New stronger front shaft and fuel/transmission lines
8. Rear Tire on Driver's side. Very close
9. Location for the CO2 bottle for the AMS-1000 (behind passenger seat where the jack and tools used to be)
10. Electric Fans saved a lot of room! Noticed we painted the mounts, thermostat housing, alternator, etc
11. Bracket was made around for the throttle for a mount
12. Vacuum block to help clean up the wires, partially visible is the wrap around the heater box
13. Heater box, vacuum block, wastegate
A few things remain to finish up. The EZ-TCU needs to be wired. We have to install a rocker panel cover with switches to control the radiator fans manually, the rear transmission fan, and the electronic cutout. Connections and wiring will need to be wrapped up on the AMS as well. Lastly, we need to put the brackets on the rear calipers. We will be doing a BOSS 302 Procharger install next week, so progress will be slow. I would think by next Friday it will be drivable! If anyone wants to see particular pictures, I'll do my best.
