Slyclone
Well-known member
My typhoon was doing well up until the other day. I snapped the alternator bracket clear off. Truck seen some high coolant temps due to lack of being cooled down. I lost my steering first and realise that i should pull over. Looked down to pull over abd my temp gauge was 1 bar under the max temp of red indicator.Drive belt system stopped. Was it too late?
With engine temps up, could I have compromise the condition of my turbo?
All the sudden... I can not get the truck to boost above the first red boost bar ( 5 psi?). Just practically stepped on it to the floor and barely rose above the first boost bar. I'm used to seeing it shoot up around the 2nd to 3rd bar no problem.
I'm going to look over all the connections again and make sure nothing is real loose.
Anyone have any tips or pointers? Sort-of stumped about this turbo/cooling thing in regards to if I destroyed my turbo. Oil was probably hot. Boiling hot my guess is. I'm thinking worst case scenario right now.
