Re: Sy #2875 Build :eh:
Here's another update guys! got some more done in the last few days!
So I got my valve covers and fuel rail sanded
cleaned, taped and set them up in the booth for paint!
Mixed of my paint, (base left, pearl right) named the base peach cobbler haha, its
just what came to mind. and pearl coat 24K
After 2 coats of base
After 3 coats of pearl
And finally 2 coats of clear :lol:
Also got my tabs for my motor mounts, I'll be using a factory GM LS1 mount that bolts to the motor and ill be making a solid type mount that bolts to the frame.
I had been looking for a LS6 intake for the truck but decided I can add that later if need be. In the mean time though the factory LS1 intake had this emission hole in it behind the throttle body, I found out the LS1 C5 corvette intakes didnt have this hole, However otherwise were the same. So I scored one of these locally and picked it up!
Factory Camaro LS1:
New (Factory) Corvette LS1:
And installed!
Then I started to clean the gas tank ect for re-installation. Threw in a Walboro pump to!
Took the hoses off, sending unit out, cleaned it sanded it, primed it and painted it!
Back together!
In between drying time with the gas tank I got busy seperating the factory 700R4 and transfer case as well as seperating the 4L80E and attached transfer case. I made quite the mess!
Installed some of my Prime Gears 4L80E kit since I was working on mocking up everything! Some parts werent installed as everything obviously had to come back apart so I can send the trans to get built!
Got the 4L80E and transfer case together and dropped it in with my 4L80E tubular crossmember.
Then the motor came off the engine stand and made its way in there as well!
My Father trying to put my drivers side headers on, but of course ran into the start of the problems as we knew we would.
So we had to cut this un-used bracket off of the trans.
Got the header on, set the motor where it neede to be and snugged up the mounting points so that we could roll the frame outside and bring the cab inside to put on the hoist to lower it back down on to the frame!
I guess i'll break the news now...the truck is going one of my favorite colors 2005 Subaru STI Aspen White.
Decided to put set my valve covers and fuel rail on since I had picked them up the following sunday after painting them and i wanted to see the pearl in the light!! So on they went....
Rolled the rolling chassis back in after putting the cab back on to the hoist, started lowering it down...
ran in to a few problems with fitment, did quite a bit of moving around and adjusting...still have tons of fitting to do ect but its getting there...
Got a few new parts for the build that came in this week too!! it was like christmas!
Diamond Clear H4 Headlights
Diamond Corner and Marker lights
Circle D Specialties - Tripple Disc, full billet 3500 stall, Its simply georgous and very light compared to stock!
Stand Alone Wiring harness custom made from Speartech Fuel Injection Systems
My new Renz Fab. front brake kit (Thanks Renz!)
Took a break from fitting the cab and finished up my rear coil set up! I had said i wasn't 100% happy with the coils and the way they were mounted. So we changed the upper position of the coils, mounting them on a angle to help adjustability and ride quailty. Also got a great deal on a set of new single adjustable rears that i couldnt pass up so i picked these up because my previous rears had no damping adjustment.
New coils
Final crossmember bar
Painted it and re-installed :tup:
Oh and then we finished setting the cab down on the rolling chassis....
its too bad it cant stay this low
Thats all for now!
