NOJIMMY
Re: Launching with four drag radials
1. With all things "about equal" (hp, vehicle wheelbase, traction, etc) can a transbrake
launch be made with a non-transbrake transmission using boost/brakes?
2. Is the weight of AWD preventing those wheel stands, or is front traction?
3. Is handling a "real problem" with AWD wheel stands, as the front tires
(assuming an open front diff) would be pulling one way when grabbing, or in
a posi-type front diff pullling various ways depending on weights put on front tires)?
4. Are the wheel stands (seen on RWD Typhoons) not possible on a RWD Syclone?
5. Does it damage much when under full acceleration the vehicle comes down
and thats why most have installed the tubular control arms, coilovers, etc?
6. Could a AWD with the prop shaft removed and rear slicks do a wheel stand?
7. and lastly, it would seem that the best ETs would be run without wheel stands.
But they sure look cool. Gotta be scary tho (I would Imagine).
Which brings us back to the original thread, and trying to figure out launching
with four drag radials. I see Ed is trying different tire sizes (front/rear via gear ratio changes)
from the normal 26in dia tires. I think he also had 8.25 wide fronts and 10 or 11 inch rears.
So one also has to wonder (for weight transfer to the rear) whether rear traction lowers
ETs? Tho Robert seems to launch level and straight (with drag radials front, slicks rear).
-Larry
...thanks for the reply. Not to hijack this thread, but Ive been wondering about this.I have personally done a awd wheelie, wasn't sure at first so had someone outside the truck take a look, no pics though
-Larry
