Launching with four drag radials
Re: Launching with four drag radials
I back them off for normal driving. Unless you hit a huge pothole you dont know they are there.
nastety92
Sounds good Maverick, thanks for all of the info, you've been very helpful and informative.
Nick
It's just a six
Super Member
Six-is-Enough said:
It does have front limiters and my best is a 1.638 to be exact. On that pass it was a 1.65. Also note that I have an 4l80E transmission. The 1st gear in a 80e is like a 2.48 compared to a 700r4 4.06. This hurts my 60' a little bit. I run the stock turbo and stock motor also.
Just the ratio is off for first gear. It's not 4.06 for the 700R4.
No harm, no foul. :)
It's just a six
Super Member
NASTETy92 said:
I have a 92 Typhoon and I'm running four Mickey Thompson drag radials with stock rims. For people who have four drag radials, do you get the drag radials warm before launching? Do you do a dry hop to get them cleaned off? Does anyone roll through the water box and get all four smokey? I've talked to a bunch of people with these tires but they all have RWD cars and say they love the MT drag radials, but they all do burnouts before launching and thats kind of hard for me. I'm sure my truck can do it, but I know the drvetrain is taking a beating.
Any and all comments would be greatly appreciated.
Thanks,
Nick
If you have a stock low stall converter, it will be very hard to burn out.
Usually you do not want to do a burnout w/threaded tires,,, water goes into the threads & kinda stays there. Then when you are ready to launch, the water comes out of the threads onto the pavement causing your tires to slip.
What mods are done to your Ty?
The JS & RPM Coilovers using the QA1 Shock will also act as suspension limiters because of the shock travel. I think Dunstan would act this way as well, PEP will NOT the bilstein have tons of shock travel.
NOJIMMY said:
http://www.fscmag.com/techstory/issue1004/techstory1004.html
Unfortunately this article is not the full article. I did find the BFGoodrich portion interesting and it backed what I suspected. The tire need 160-180 degrees for full traction. My friends with them have always commented that they hook much better with a small burnout, its kind of tough to do that with a SyTy. I have held off getting DR because of this. The MT aren't tires I would buy (not enought street miles) We really need a tire that is sticky at its operating temperature.
Ryda85
Senior Member
dam i was planning on these....how come they are still on their site? well looks like i will start looking for a diferent set
NOJIMMY
what ever happened with green dots
You may already be aware that green dots are tires that are re-treads.
The compound was supposedly soft, and since the tire sizes came in stock SyTy wheel rim dia & widths,
some folks used them for racing. The thought <I think> was that they were cheap,
and for 1/4 mile, not that much of a risk for blowout, tread separation, etc.
But realize, Im guessing, as I dont think they are available amore.
Personally, I agree with Dave. The trick is to find tires that have a compound, and
size for our vehicle (if you dont have the luxury of having two sets). Nittos are known
to last somewhat longer for street use, but the compound is not soft. Some,
like the M/T`s require some amount of heating, and are problematic on rain/street conditions.
Hoosiers come in radial and bias ply, (bias ply doesnt flex like radials), and I hear they
also require hazing for grip.
BF Goodrich are somewhere in the middle.
So the trade off can be:
-Are you confident that green dots (if available) are safe for your hp/torque/application
-Can you afford 2 sets of tires (for street, for strip, for fronts and rears, or for rears only)
-Do you need "lots of grip" which usually means lots of parts breakage (axles, prop shafts, u-joints, trannies, etc)
-Can your suspension handle "lots of grip" (axles wrap around, wheel hop, etc)
-Would it make more sense to tune, and concentrate on more top end top perf mods
-Is you stall converter sized properly, and would your brakes hold for higher boost launches
-Is your vehicle lowered to the point that cladding, bump stop, or other such problems occur
-Is your reaction time so poor, that even a great launch might not help you or tranny shift points
-And do you visit different tracks (or streets) which vary greatly in traction anyway.
...I found an article long ago that mention "storage" of drag radials/racing tires was a often
overlooked point. They claimed that taking the tires off the rims, wrapping them in
air tight plastic, and keeping them out of heat/sun preserves the compound for future use.
I hear bias ply tires can separate under weight; dunno if radial cords do the same.
As I cant find the article anymore, and there is seems to be very little consensus about tires,
even among expert racers. I think Mike/RPM admitted that he was very surprised that
the Ghetto Machine pulled the wheels based on the 275`s he had on the rear.
So if 1,450 hp can hook with this size, (and if you read the Drag Week or Hot Rod
Street Winners) some of these vehicles run 8`s on smaller drag radials maybe
tires are not as critical as say tire pressure, size, suspension, track compound etc.
I remember Les/Mark (with the Stokes Sy) saying that he would rather have a bit of
"slip" than experience Ed`s front/rear/axle incident at the track. I also remember
a rather lenghty thread on green dots (safety vs speed). Lastly, some manufacturers
even post that certain rims and/or tires are not recommended for extended street use
(due to pot holes, sand, rain, ice, tar/nails/road-side junk, leaves, stop/go hiway traffic,
extended heat, etc). But I guess this is only relevant if you desired a 1-set all purpose tire.
...then again, you may have only wanted to know where to buy green dots.
And this I dont really know.
-Larry
cloneman315
i think u can still get the green dots .now i dont daily drive my sy so i dont know about long term but i do know they work and work well so far for me ,and i like them also because no one else knows what they are they think you are running stock street tires
It's just a six
Super Member
In Cali, they used to retread tires here, they were Caldwell retreads, very sticky tire.
Can't remember where there located?
NOJIMMY
This thread got me to wonder "with regard to Launching with four drag radials"
...has anyone seen a AWD Wheelie (where the 2 front tires are both off the ground)?
I looked on the internet, and couldn`t find any awd vehicle ever doing this.
We all know that the Ghettosled (see recent video postings) and Tom F`s truck
along with Dean Ollar`s are 2wd with transbrakes, and thus did wheelies.
Ghettosled video:
http://videos.brokeassracing.com/tr...tosledmovie.wmv
http://www.raceprovenmotors.com/ima...eos/ghetto2.wmv
Tom Ferrick video (at the very end of the video):
http://www.trickstitched.com/s-wars.wmv
Old Video (not available anymore) Dean Ollar:
http://www.johnpsu.web1000.com/ollardean01.mpeg
-Larry
Six-is-Enough
Use to do a little Boost
dgoodhue said:
Yeah made a mistake there. I was thinking of the total gear. Got my #'s mixed up.
700r4 1st gear 3.06 x 3.42 axle ratio = 10.46 total 1st gear
4l80e 1st gear 2.48 x 3.42 = 8.48
Also here is another video of my truck from this past weekend at a local 1/8 mile track doing burnout and launch on BFG Drag radials Believe run was a 1.65 60' .
http://videos.streetfire.net/video/1f8a4e5a-68c6-4bd4-860c-986100a6a8da.htm
nastety92
It's just a six said:
If you have a stock low stall converter, it will be very hard to burn out.Usually you do not want to do a burnout w/threaded tires,,, water goes into the threads & kinda stays there. Then when you are ready to launch, the water comes out of the threads onto the pavement causing your tires to slip.
Mods:
Build motor, 0.30 over
412 Cam
stock crank machined and nitrated
vortec heads fairly stock light port job 2.02 1.6's
Edelbrock carburated lower intake converted to FI, deleted middle seperator
custom fuel injector bungs were made and custom fuel rails
90 degree elbow for upper intake 80+mm round throttle body
83# injectors, FAST
T-63 with .83 sy ty specific housing
Built 700 4000 stall 9" converter (all Rossler parts used)
DeQuick dual core A/A with piping entering on the drivers side
Stock: rear end, front end, t-case, prop shaft and driveshaft, stock suspention
stock brakes
Stock rims with four MT drag radials
Tunning done by Xplicit Racing and Design
truck weights 3900 with me driving.
Nick
Silly
Banned
Ghettosled video:
-Larry
I have personally done a awd wheelie, wasn't sure at first so had someone outside the truck take a look, no pics though.
Somewhere though there is a picture of Ivan yanking at least one wheel. I think it was from the setting on his Rancho's. Could be mistaken but I am sure the pics is out there somwhere.
