The Devils Own Chariot
Re: FMIC project started.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250382781545
Did you get that turbo on ebay? I hope it stays together for you:?
is it possible to reclock the turbo with it still on the truck??
are you going to reclock the center section of that turbo?
I too am curious how that chinese turbo will hold up. I've heard some pretty bad reviews on them. Do you have a compressor map? specs on the exh housing? At least it bolts up/fits.
also...does the stock dp bolt up to it?
well of course it'll out flow it...its a bigger turbo. the question the map will answer is whether the 25g will be efficient with your build.I would put money down that the 25g will out flow a 20g.
lifetime warranty sounds great. Does that warranty also cover your motor for the pieces of compressor wheel it'll shoot through your motor if it fails? Not trying to scare you away from the turbo...i hope it works well and becomes a cheap upgrade for syty's. Just thinking you should be aware of it and check on it.
