Finally Bought A Typhoon! WOOOT!
jjorgensen52
NHSTE - I'm the only one!
Re: Finally Bought A Typhoon! WOOOT!
ShuggsRR said:
So I went to mess with the truck yesterday. Reset the ECM and IAC. Replaced the TPS and MAP from the wrecked Ty. Double checked on vaccum lines and everything seems happy.
Started it up again and it took a few seconds of sputtering until it sounded like it was running fine and then the the idle shot up to 2000 - 2500 again! arrgghhh... Checked the codes again and it said ode 33 - MAP sensor. but no longer says 22 and 35.
I also notice my boost gauge is pegged out top end. It is pegged with the truck on or off. WTF is that? Im SURE its not making that much boost with the truck parked on turned off. haha Any ideas?
So Im reading the service manual to figure out my next steps and everything says "check scan tool" or "use the scan tool" or "after you read the scan tool" Dammit!! What do I need to work on the truck? Do I need a scan tool or can I use my laptop?
I now understand the frustration you guys all have with these. lol
The worst part is... It ran GREAT Thurs night. Great idle, no noises, smooth power, etc etc It was GREAT! Then within an hour the idle was way up. So high Im afraid to put it in gear because it would be like doing a neutral drop.
Code scanner just pulls the codes you're listing, so you're all set there. Try swapping the MAP sensor back again, if it wasn't saying that was bad before ( pegging at idle is also a good indication it's toast :lol: ). I had a bad MAP sensor on my pickup and it wouldn't run at all, after the first week when the idle hunted between 400 and 3000 :roll:
ShuggsRR
I swapped the MAP after it gave me the code 33. "dont fix it if it aint broke!" :D
ShuggsRR
Ok on my way back up there to see if I can break some more stuff...
sounds like bad map or bad vacuum line, or wiring issue for the map sensor
ShuggsRR
The truck ran great... tursday night about 11pm. When I started it about an hour later it was idling high. So it cant be wiring or anything. Has to be something like vaccum. Would a vaccum leak make the trouble code 33 MAP sensor?
Jimmy
Banned
Yep. The MAP reads manifold pressure,so a vac leak would give it fits.i.e make it idle high ect.
ShuggsRR
So would it be a noticeable leak? Or could it be so small you would have trouble hearing it or seeing a crack?
We have searched all over all the vac lines.
ShuggsRR
Found a leak between the IC and intake... got that solved and I think there is a bit of one by the EGR as well. Would these present a mojoe issue? im sure they would huh?
Changed the plugs as well to NGKs. What a pain in the ass!
ShuggsRR
Found the problem. Replaced the vac lines and little box that sits on the turbo. Two wires going in to it and two vac hoses. Changed that out and the truck runs like a champ!
scrape
:rotf: :rotf: man thats kick ass. ive been gone all weekend and just caught up on your ty. the old guy spent all that time and money trying to find the prob and it was the alarm the whole time. if he ever finds this thread man hes gonna feel like an ass.:rotf: congrats man :tup:
ShuggsRR
Heh hes really cool. I just emailed him to let him know what I learned and the whole story about the truck so far.
MikeRenz
not stock
thats called the boost solenoid. should cost you about $18 at the dealership.
ShuggsRR
Thats whats awesome about having a spare parts truck that runs! lol
SY756
That's cool you got it figured out Greg.
ShuggsRR
So I tried some new wheels and tires today...
Posing with my next door neighbor's Lightning
Quickstop [UK]
Combating adversyty.
what are your painting plans? Mine needs a respray as well and i am really worried about how to do it...
alwayscode390
pppssssshhhhhtttttttttttt
WOW BRO under $4500 AND under 90k miles!!!??? All it needs is paint, I mean it has a NEW engine and nice interior!!! ---
ShuggsRR
Im going all factory original. Green and grey factory paint codes. All stock all original for me. My Tyclone is the modified beast!
Yeah Ima bit concerned but i think with the messageboard and the help of my friends who do body repair... Im in good shape.
Yeah im pretty excited.
ShuggsRR
I just detailed the interior... WHOOO its all near flawless except the leather onto of the shifter. I guess he drove with his hand on the shifter and wore the leather.
