Re: DB MN Dyno
Having it in D, and not in overdrive was the right way to do it for measuring power. You want to have it as close to a 1:1 drive ratio as possible. How did the truck feel when not at WOT? Any off idle stumbles, hesitation, or weird a/f ratios? I'm assuming you also had as much airflow as possible across the IC to keep IATs in line (hard to do inside). If you plan on trying to run higher boost at higher RPMs, you also need enough cam to let all that air in and out. Also have to factor in driveline losses. Good luck with the tuning!
