17x10 questions, on all four corners
IDRVSLO
When Hell Freezes Over
Okay so in my wheel searching I found a set that I like....for a good price. They are a 17x10 wheel with a 50mm offset. Will these work with the following setup on a lowered Sy? What issues might I run into.......I know the rears will be fine...more concerned with the front.
-5x4.75
-50mm
-275-40-17s on all 4 corners
-Direct bolt on the front
-25mm spacer on the rear
abes_sy
SY #2995
Re: 17x10 questions, on all four corners
I had the 17x9.5 zr1 wheels in the front and the only problem i had was that the wheel would rub the upper a arm when turning the wheel all the way to the left or right.
IDRVSLO
Also will I be safe to run my 275 40 and 315 35s? I know the 315s will be pretty meaty on there, any thoughts would be appreciated.
IDRVSLO
Thanks!
If I remember correctly the ZR1 has a 56mm offset, so these being a 50mm they will have the same inner clearance. I should have just checked the offset calculator and compare it to the ZR1s...duh.
So with the rear spacer I will be sitting 13mm out in the rear and 16mm out in the front. In reality that is not bad at all. Now to run my 315/275 setup....hmmm. Either I get another 275 set or I just stick with these.
gt67sy
I run 10.5 wheels up front with 295 tires but I have rpm tubular a-arms
IDRVSLO
Wheels are going on tomorrow, I am sure with zero issues!
sychris
i run 275/40/17 all the way around . no spacers no rubbing in front maybe very little rubbing turning real hard . my wheels are 17x9.5 with 54 offset . i have spacers in rear
IDRVSLO
x2
With stock a arms I say your going to be making allot of unwanted contact
Either way they never were installed. But if you used the calculator you would have seen that they would be further out from the inside then the ZR1 wheels are. So they would have fit better in regards to rubbing the A-arm.
The wheels showed up with one being bent beyond what is ever acceptable. Paypal claim was filed and I ended up grabbing a different set.
I hate people sometimes.
Flyin Ryan
hated cuz he drives fords
Wow that sucks but glad you got your funds back painlessly through paypal and went with a different/better fitting wheel
