nallj92
Re: What now? (UPDATED!!!)
serial timing is why its not keeping a connection, read the readme file for datamaster, helps tell you want to adjust.
to record, under the serial data screen go to file open and type in a random file name for the run and then hit open it makes this a new run then you just hit the record option.
for a run do some driveability, like crusing and light acceleration, look for knock and such., intake temps, inj duty cycles, boost control.WOT timing. then do a hard acceleration from 10-mph and go throught the gears. if you want a 1/4 mile run is fine, then you can use the 1/4 mile calculator if you record that. as long as you got WOT throught 1st2nd 3rd, that will tell whats happeneing with stuff at WOT
