UR50SLO
V6+2=LSXCamaro
Hey fellas...
Got the new motor up and running but I can't shake the code 43.
It came on right at startup. Before I set base timing.
When I did disconnect the tan/blk wire to set timing it did make a differene and I set the timing to 0deg.
Plugged it back in.. disconneced the battery and the 43 came back on.
Took the module out and had it tested.. (it was ok) They replaced it anyway..
did not make a difference. I do have a new Knock sensor. (Jeff said that does not matter)
Grounds?.... One on drivers side rear head and one on T-Stat housing.. (plus one main)
Nothing has changed since the happings at Sy/Ty nats........?
ECM/ECMB fuse good... Suggestions?
I need help getting the Autoprom/Tuner pro setup so I can set some fuel tables differently.
The camshaft change and heads ect has changed alot of how it needs to be fed fuel.
it's now lean on the part throttle and rich at idle... Needs more fuel at mid to top too.
Sure sounds good... Just need the 43 solved and fuel tables set right.. after that I can
play with Ign. timing.
Anyone close to Indiana that knows Tuner Pro? Autoprom?
Thanks for any help...> Scott~
