Other caliper options
warmpancakes
Re: Other caliper options
Hmm looking at those pics again Im going to go look at my callipers my are different they dont say corvette and they are early production , so I might be wrong. They are early proto build pieces.
leadfoot
supersports10 said:
if you dont want to cut your stock spindle, there is another option.... 98 and newer 4x4 s-10 blazer complete spindle set with brakes, rotors, hubs, abs sensors, and dual piston calipers. these are very nice units, and bolt right on, where your stock spindle was.
i have done this conversion to 2 of the truck's that i own, and it is money well spent.
a guy sels the complete assembly's on e-bay for $255
seller id is s10wharehouse.
hope this helps.
SS
I have these on the frame I bought. I thought they were rather heavy compared to the rear aluminum calipers.
canadian
sy in progress
they fall out of the back of a truck into your garage? or do you have the inside line on those kinda parts?
warmpancakes
I just tested a set of production 2006 Z06 callipers and I was wrong they do bolt directly on and the hoses work :tup: Sweet now I have 6 piston fronts.
chelo
filthy sy
Look at the size of those new calipers. Almost looks like a porsche setup. Very nice. I bet those brakes up front would want to make a sy's rear want to lift up.
TT350
Manufacturer
That's what makes playing with GM stuff so cool.
E-Rue
now we just need someone to make a rear kit to go with all these front kit options.
e
warmpancakes
Get the Ls1 brackets and there is a kit made to C5 or c6 brakes on the back they are only dual piston , but you can get 13inch rears,
E-Rue
i havnt seen any kits for corvette brakes on the rear of a sy/ty or S-10.
if you know of such a thing let me know. id love to have 13" rear brakes.
e
warmpancakes
You have to convert to Ls1 brakes first then you do a second upgrade you only really need the calliper mont like 90 each from the dealer.
E-Rue
which caliper will that use? the C5 one or the new C6ZO6 one? isnt the C5 one a single piston? not that thats bad..... id still be ok with a single piston. just trying to figure out what parts i need. anyone sitting on a parts list? or a how to artical?
e
'JustDreamin'
Dream: 6LV8 Turbo Bravada
The C5 fronts are 2 piston (supposed to be 40mm pistons, haven't measured), the C5 rears are 1 piston (don't know size). I'd love to see a parts list myself. I've got a parts list for the C5 fronts, but that probably isn't what you're looking for.....
'JustDreamin'
BTW, how those LSx oilpans coming? Just bought a '99 Bravada, and its definitely has an LSx motor in its future.
MRKING
New Parts for Old Trucks
warmpancakes said:
You have to convert to Ls1 brakes first .
Done .
Sh*t , I just now finished my rear disc install and already I have to upgrade . Whats new I guess . Got a p/n on the new caliper mount Ken ??
warmpancakes
If you have the ls1 rears you have the caliper mount you just need the rotor and new calliper, let me find the info.
chelo
filthy sy
After reading this thread, I started doing some quick research. the new c6 Z06 brand new calipers are 6 piston front - four piston rear. 14" front rotor and 13.5" rear rotor. You HAVE to use 18" wheels min. If your using these rotors in the rear of a corvette and would have to run a 1/4" spacer. Many syty people already use spacers. C6 Z06 front calipers ARE currently available for around $600 for the pair of front only. The set of rotors, front and rear are almost $400. The only drawback is the set of brake pads(4 wheels) are $500. When looking at this set compared to brembos. They are very cheap. Even using camaro rear disc and new c6z06 front calipers. It would be an incredible upgrade. From what i read and the guy i spoke to. There way better than even stock vette. I will be ordering a set for the front only. The drawback for me is that i have to buy 18" wheels.
