OK, briefly the Sy died last week. Replaced the coil fired back up. Replaced the module for good measure. Truck starts a bit quicker, especially when warm. Runs nice, EXCEPT...
Slight lope at idle. Always been there, just mention here in case.
So, I head off down the street and I have a random miss. Almost a shut down only it happens for such a short period of time it's hard to call it that. Things that happen when this occurs are:
Tach dances 4-500 RPM up, down, or both.
Caught one very quick flash of the CEL, no code on DM.
WB goes lean. I assume here the inj's have quit for that 0.1 of second that it happens.
Trans drops out of lockup.
Caught it in one DM log. On just one record ECM went from closed loop to open loop and back.
I plan to start by eliminating some obvious items. I'll bypass the bat kill switch. I'll replace fuses even though they test good, ya never know. I've already bypassed the MSD 6al, no difference.
Doesn't seem to happen at full throttle but haven't done a 0-100 pass either.
My hunch though is somehow the ECM is going "off line" so obviously will check everything there as well.
Someone said I should check the pet rat on the wheel but last time I looked he was still going.
I'm NOT a fan of intermittent electrical gremlins.
Thanks all.
Thanks all.
