Last drag of the year Ty #1215 (12.3)
alwayscode390
pppssssshhhhhtttttttttttt
Re: Last drag of the year Ty #1215
WOW, I am very happy for you.
What a nice truck... I bet you are super proud of it , especially at your young age :) ---
e95 Ty
Re: Last drag of the year Ty #1215 (12.3)
Really happy for you....I know how much you love that truck. I hope you continue your excitement for your Ty, its contagious.:tup:
Sean Krupa
Moderator
Back to the Track with new Setup
Going back to the Track in a few weeks. Will be installing my Coilovers this week which should net me 50lbs off from last year. The Ty definetely feels faster than last year with the new 3200 Vigilante/Built trans. I was struggling building boost with the stock converter and now I can build whatever I want in a few seconds. I will have my Limiters back in and hopefully I don't spin too bad.
I will be running the same tune as last year, 20psi with about 22-23* advanced timing. What ET do you guys think I can get now with the new converter? Hoping for 11.9 or better.
Thanks,
johne30m3
Junior Member
Re: Back to the Track with new Setup
Thanks,
Easily high 11's.
92TyLA
Easy 11s man! Cant wait for a vid when you get into the 11s
wildphil
I Love My Ty's
You should make a time you will be happy with. Have fun!!!
killa66cam
RIDIN DIRTY
Hope that it goes at least high 11's. I am probably going to be doing a build close to yours. Good luck!
Cam
SYCLONE#1531
'MOFOFAST
You should be able to crack it in the 11s! Just gotta keep it from spinning! And don't forget to manually lock the convertor!
Sean Krupa
Moderator
Thanks guys! I don't think I'll be manually locking the converter. Kinda don't wana hack up the wiring and add a switch.
berzerker
wookie
only need to run wiring and a toggle to the aldl port for the lock up . the tcc lock up will happen in second gear . dont know the excact pin locations. but it's been discussed many times . good luck at the track hope you hit that goal .
RealFastV6
@jb_and_his_coffee
Top Left to Top Right. Same as a GN.
I understand what he's saying though; if he's logging using the ALDL then really he'd need to splice behind the ALDL connector.
Aeroking
e.i.
can't you cut up an ALDL cable and wire a switch into it. Then plug it in at the track.
