Sean Krupa
Moderator
Tomorrow night I will be racing the Ty for the last time this season. It will be about 50* so it should run well. Earlier this year I had some problems with the Alky kit and could only run 14psi safely on pump which is now fixed.
I'll be running 20psi with about 22-24* of Timing. Hopefully I'll be in the mid 12's. Still on the Stock Torque converter so building boost will be the issue. Will do the best I can without cooking the trans.
The Ty pulls a lot harder than last year with the Stock Turbo. Hopefully I get a good enough base line to compare to next seasons Built Trans/2800 9/11 Stall/2step.
I'll post a video ASAP.
