teamvortec
Re: Fastest stock turbo?
That might but true but he does have an issue if the iat temps are rising that much and he can't see any coolant moving in the upper with the pump running. As for timing I have mine set at 0 degrees with the wire unplugged. When you set your timing take an extra minute to inspect your balancer to make sure it hasn't slipped.
This is my opinion only, but I feel one of the problems with the stock intercooler system isn't the cooler itself, or the heat exchanger down below. I don't feel there is enough capacity of fluid in the entire system. Less fluid means that it will heat up quicker.
I think an ice box or just a 1-2 gallon reservoir would make a huge difference.
