On 2002-04-05 10:29, SY732 wrote:
What is the fastest a SY has gone with:
Stock Motor,
Stock Turbo,
and
Stock Trans
Stock Motor,
Stock Turbo,
and
Stock Trans
I used to think that was me at 12.4 @ 106, and you with a 12.4 but a lower mph? Wouldnt our hardcore drag racing friend Chuck conform to the above while running a 12.0?
Rick out in Cali has a "claimed" stocker that does 12.2s with drag radials and race gas mixed with 93 octane (I used to mix as well). He has done some interesting tricks I hear, running an ATR chip to boot.
Some others were getting real close to 12.4s, I am hoping we knock it down to at least beat the 12.2 Rick ran.
Anyone got a timeslip close to or faster than 12.4 with the above hardware? Be cool to see us stockers get a few more tenths..
_________________
Daron
1992 Typhoon Blue/Gray
1991 Syclone Best 1/4 12.42 @ 106.1
Member Of Freakin' Ohio (MOFO) SyTy
<font size=-1>[ This Message was edited by: Daron on 2002-04-05 16:20 ]</font>
On 2002-04-05 17:20, Christian Dionne wrote:
Charles Blossom went 11.90@115.01 Oct99 Clermont,Indiana in the AT/SA class. The truck must weigh 3550 plus 170 driver.
He also went 12.09@111.27 Jun00 Brainerd,Minnesota in BT/SA which has to weigh 3810 with driver.
Doesn't he have headers, converter and DFI?
Yep, even though these two trucks are in stock eliminator class, it really isn't a bone stock deal... You can replace the ecm with a programable one, gears, headers, injectors ect... I have the rulebook right here... I think the gears are even changed out to 3.73/3.90's...I will be in Montgomery, Al. this weekend for the div. 2 points meet and I hope to see at least one of these guys running...and putting the smackdown on a couple of dodges that I know...oh yes, L35 rods are allowed along with certain forged pistons.. rpm range has been moved up to about 6k...On 2002-04-05 17:20, Christian Dionne wrote:
On 2002-04-05 23:25, woundup wrote:
AT 6500FT. ALT. MY TRUCK WITH STOCK TURBO, ENGINE AND TRANS. WITH ONLY BOLT ONS RAN
11.87@ 119.6 MPH. GOT IT ON TAPE.
On 2002-04-05 22:20, TookyCat wrote:
What is the fastest stock, stock truck using stock chip and stuff? I have heard of some 12.9 using stock chip but with headers or other major mods. I am aiming to run a 12.9 with my stock truck this spring, don't know if it will happen or not.
Kris, I have already went 13.36 @ 97 MPH with the stock chip and the only mods of drop-in K&N, 160 thermostat, 3" ATR full catback exhaust with original catalytic converter. I still have the factory original IC pump. Here is what I have going for me, to run faster. When I ran 13.36 my boost was hitting low points of 12 PSI. If I solve that, that's 3 extra pounds of power. Also, I was using factory original 12 year old SVX tires that were bald in the front and launching at 1 PSI caused wheelspin from the left front tire enough to generate "burnout rubber" in the wheelwell. I have brand new ViperHX tires now and plan to launch much higher than 1 PSI. In addition those runs were made after 50 minutes of idling with the engine on. If I can run with a cooler motor it might be worth something. Finally I was getting as high as 4.6* knock retard. If I can solve that, that's that much more timing to make the run with. So put that all together and I think I can come close to a 12.99 pass. I mean the tires alone will gain at least a tenth. But I won't know until I try! :grin:On 2002-04-06 09:21, SY732 wrote:
The fastest Stock Class SY I think was mine ran 13.4@99 at KCIR in 2000
I think Troy went 12.9 with an ANS and no cat back.
He has a built motor now!
Without getting around the Stock Chip I do not see how one could go faster than 13.2, how do you plan to do it?
