Re: Adapter Plate
Nope, same bolt patern. What are the details of your biuld?
That's technically not correct, but pretty close
The bolt hole at the ~2 o'clock position on an LS motor doesn't exist, because there's a water jacket there (don't try to drill the hole).
And the LS motor has a bolt hole at the 12 o'clock position, which the T350 doesnt' have.
However, it will bolt up just fine without that 1 bolt. It should be stout enough for most applications.
You could have an adapter made, I don't know of one available commercially.
You also should check on the crankshaft flange location. I seem to recall you need a spacer on some cranks, and not on others. I'd suggest looking over on LS1Tech.
'JustDreamin'
