do you have a pic of the relay and plug you need?
Here tis..... lower right one of the three. The fuseholder is in-line in the jumper lead so that one can turn off the pump when doing service with the engine off (I've got my 7" CAC fan wired through it as well).
Hey Dig,
Since you're going to be splicing anyway, I wonder if you'd want to use one of the weatherproof Omron relays and sockets. I just ordered a few to do my purple wire bypass, and to re-do my injector isolation circuit.
Hang on, I'll look. I think I do.
dig , still need the stocker? i took mine off...
yep snipped it off.....curious what you have cooking up with this... secret project?
Hey Dig,
Just a side note for peeps hotwiring the IC, not sure that's what digs up to, but I found I didn't need to splice into the yellow wire. I just opened up the relay connector cover, real easy, shoved a wire right on top of the yellow wire (yes, where the pins are), closed the clamp, and grounded it. Took about 5minutes and I didn't have to cut anything. You have to make sure it's tight when you reclamp it, don't want it sliding out or it won't be hotwired anymore. Helped keep it looking clean.
