skipztt
boost
ok i just got done taking the ty out for a spin, around the block or so. anyway before i went i hooked datmaster up to it. i have the moates extreme aldl cable and i know the cable and everything is good. its basically brand new.
first of all i just got done redoing all the vac lines on the truck which was needed badly. whoever owned the truck befoe me must like to half ass everything. :rant: i also did a tune up new plugs (ngk ur5's, gaped to .032), wires, cap and rotor new TB gasket (cause i thought i had a bad vac leak from there. i doubled checked all the vac lines a check valves to make sure everything was correct, also everything got zip-tied.
so after 20 minutes of messing around with datamaster and the COM ports i finally get the thing to connect :roll: ...im pretty sure im doing it the proper way. tuning the key to "ON" position and letting datmaster connect to a COM port, let it start to gather data, then start the truck.
first thing i notice is, my idle is higher then normal. its at 1025rpm, which is wired cause its normally around 900-850ish. so i decide to drive it down the road to test it. when i put it into drive, the rpm's go up, then they go down, when its in gear.
when im going down the road it drives fine. everything seems normal untill i have to slow down. when i hit the breaks, it allmost seems like i still have my foot on the gas pedal or the converter is still locked??? the rpm's stay up untill i completely stop , then they go down to normal :banghead: :roll:
another thing i noticed was if i was cruising around at 35mph or so, once again is seems like my converter i locked, cause my turbo just screams crazy loud (i kinda like it... :lol: ).
************************but i did pull a code about halfway through my datamaster record. it brought up MALF 35: IAC error.********************
anyway im heading back to the house and the ty starts the sputter, so im praying to god i get it back home. i have to feather the gas so it dont die on me. but i do get it back home. i park it and let it idle for a sec then it dies. :rant:
now if i take datamaster off my truck and then drive it. NONE of this happens :squint: it drives fine and no weird "coverter "thing...none of it.
so any thoughts or ideas i should look into. this thing is driving me nuts..lol :rotf:
oh yeah, i do have a newer fuel filter on it a 255 pump, afpr. i have a fuel pressure gauge but i dont have it hooked up yet. i have an isolater now cause i have the gauge inside the truck. i just have to hook it up :roll:
