white smoke
Phoon30
Might just be condensation in the exhaust system. Does it happen every time you start it? Or just when the truck is cold?
cr133r
With synthetic oils, it will look pretty close to white.... Really hard to distinguish between water and oil...
Are you losing water at all? If not, most likely valve seals.
myclone
Rick_From_Mi said:
My TY blows smoke when started only when cold. Is this bad valve seals also?
Thanks
-Rick
More than likely yes.. or condensation from the temp difference in the outside air and exhaust gasses.
Valve seal probs should go away in ~10 seconds or less IMO..
