The Yeti
Got 1000 hp?
Re: What would make the ECM go into limp home mode?
I'll try the fuse now, been fiddling with the truck since noon. Also, what scan tool is recommended?
Edit, removing fuse at operating temp makes no difference. Seems like it only relearns after a long time being disconnected.
Edit the edit: Grounds are great. Getting 14.43 volts anywhere with engine running.
i meant. the ecm goes into learning mode when you reinstall the ecm fuses. i was saying that once your engine is at operating temp. take fuses out for a few seconds, and reinstall them and maybe it will leanr it selve to be good.
also you need a scan tool to see what kind of values you have
