Re: what oil to break in the motor?
sy1219 said:
I was told NOT to use Syn. oil to break in the motor because it will not seet the rings the right way. But the turbo requires Syn. oil to survive. What is A good oil to use to break it in?
Thanks!
Conventional 10w30 is fine for 1st 500miles, change it again to conventional 10w30 again and then after another 500 miles can go to mobil syn or any other syn products.
We ran my old motor on dyno with std 10w30 off the shelf broke it in, pulled filter cut open and looked at oil and fill it back up with new mobil reg oil and made like 7 dyno pulls 605Hp / 630 Ft. Lb.s and then ran for about 500 miles and started using Mobil Syn.
Lasted 2 years of Racing it. Changing set-up a bit and new cam design and some imporovements. Stock Crank, 4 bolt splayed, vortec heads, custom cam, GT35R Turbo.
Ralph
