What Kind Of Trans Temp & Fuel Pressure Gauge to Buy...
ShuggsRR
Do I want electrical or mechanical?
http://store.summitracing.com/compare.asp?N=700+400442+300131+4294905502+115&autoview=sku
#1
Gauge, Z-Series,
Transmission Temperature,
100-250 Degrees F,
2 1/16 in.,
Analog,
Electrical,
Footnotes:
22 - Includes 1/8 in. NPT sender.
23 - Air-core meter movement.
34 - Includes 3/8 in. NPT adapter/fitting.
35 - Includes 1/2 in. NPT adapter/fitting.
46 - If mounting in a steel pan, model 2260 bung in the Accessories section is recommended.
#2
Gauge, Z-Series,
140-280 Degrees F,
2 1/16 in.,
Analog,
Mechanical,
29 - Includes 8 ft. tubing or wiring harness.
45 - If mounting in a steel pan, model 2261 bung in the Accessories section is recommended.
speed_addict
Re: What Kind Of Trans Temp Gauge to Buy...
The first link is a comparison on your own account (link is dead)
I would go with electrical for safety reasons. Im not fond of any engine fluids in the passenger compartment. I use the fuel pressure gauge (mechanical) as a source for my madness.
ty166
i ALWAYS run electrical, for the reason speed said , a good example is when i was in high school i had a mechanical oil pressure gauge that sprung a leak and leaked into my stereo igniting what turned out to be a complete vehicular meltdown..... lets just say a burning car lets off alot of smoke , plus to get the ends of mechanical temp gauges thru the fire wall it takes a very large hole , like 3/4" if not bigger. electrical also look neater , dont have the larger spring covered sender wire running all over. electrical gets my vote.
ShuggsRR
That shows my ignorance. I didnt realize that mechanical meant the fluid is right into the passenger compartment. NO THANKS! The electrical one is cheaper anyway!
$42.88 to $59.88
speed_addict
Yea right on Shuggs..... the only mechanical you want is boost (air)...
I may be wrong but Im pretty sure the tech at the track may look shitty on you if you want to bring any mechanical gauge into the passenger compartment (besides air - most fluids are frowned upon)
just a side note... you can get a fuel (electrical) sender for electrical gauges like I did on my eclipse for the fuel pressure.... some arent recommended but i have a mech under the hood also... just a thought
ShuggsRR
Yeah I plan to do fuel pressure as well. You mean buy en electrical fuel pressure gauge... right?
speed_addict
YES... if you buy on eBay like I do be careful, the mechanical are cheap, the electrical are more expensive.
I dont think you want 40+ PSI of fuel in your face do you?
I go with a mechanical on the FPR in the bay and then a fuel pressure gauge (electrical) in my face - not nesacary (sp?) but i rock it.
gjp
another post whore
you will also need a sending unit. then run just one wire to the guage. You will need a ground,power and light controls to on most guages.
ShuggsRR
This is $125 as opposed to AutoMeter's $180+
I was looking at this gauge...
http://store.summitracing.com/partdetail.asp?autofilter=1&part=NRD-M8034-RB&N=700+0&autoview=sku
Nordskog Street Series Gauge,
Digital Fuel Pressure,
0-100 psi, 2 1/16 in. Diameter, Electrical,
With this sending unit
http://store.summitracing.com/partdetail.asp?autofilter=1&part=NRD-S8434&N=700+0&autoview=sku
NRD-S8434 Sending Unit, Fuel Pressure, Each
jjorgensen52
NHSTE - I'm the only one!
Re: What Kind Of Trans Temp & Fuel Pressure Gauge to Buy...
Highly recommend the Norskdog digitals, I have a trans temp in my Ty and love it
