What get Eprom
Hi guys.
What get Eprom?
For this it is necessary to remove panel?
Thanks.
SBNova
Re: What get Eprom
Remove the underdash panel, and probably the pass side kick panel to get to it. It is mounted vertically, and held in with one bolt.
Re: What get Eprom
Thanks.
What is necessary to use that hereinafter possible was change Eprom not removing underdash panel?
AUSyTyIN
Unbusted $#it box
Re: What get Eprom
If you want, you can type in Russian, and I can get someone to translate if it would be easier for you
ty166
Re: What get Eprom
:rotf::rotf::rotf:
SCWolverine
Re: What get Eprom
Divette said:
Thanks.
If you want to burn and physically swap chips frequently, consider moving the ecu to the glove box. http://www.syty.net/forums/showthread.php?t=39246
Some people will just "secure" it below the dash until they're done tuning (swapping chips).
If you're using an emulator, you could leave it in the glove box, and the ecu in stock location ("permanently" connected), lots of options...
Sorry if I misunderstood the question, but I think I'm with you. Your English is far better than my Russian regardless.
Re: What get Eprom
If you're using an emulator, you could leave it in the glove box, and the ecu in stock location ("permanently" connected), lots of options....
SCWolverine
Thanks , you have understood me it is correct
