Weird electrical issue.
crashing_sux
Blow Me?
So last night my truck started doing something a bit silly, I noticed that my dome light wouldn't go off when my headlights were on. The first thing I thought to do was check my dimmer dial, but when I turned that all the way on (which normally makes the dome light come one) the dome light turned off and the floorboard lights came on. It's an either or thing. Even stranger, when the dome light is on (dimmer not turned past the "click" for all on) my cigarrette lighter outlet doesn't get power.
Strange, I wonder if some wires were screwed up when my stereo was stolen?
crashing_sux
Blow Me?
Re: Weird electrical issue.
Damn, with three identical responses I thought I'd found the first easy problem with my truck. No luck, I checked all of my fuses, everything is good.
crashing_sux
Blow Me?
Yikes, I'm going to have to get one of those test light thing-a-ma-bobs and learn to chase this stuff down.
crashing_sux
Blow Me?
Thanks for the tip, I'll check it this weekend. Are they just bolted to the firewall? I've never looked down there too closely but don't remember much except the fusebox.
myclone
Its right above the E brake pedal when its in the up position (E brake not applied). Position yourself best you can on the floor of the truck with your head just under the dash and look straight up to your right above the E brake pedal. Its a 10mm bolt that holds the lower corner of the dash in. Youll see it (youll prolly need a flash light/drop light though).
You said you checked your fuses but this sounds REAL similar to what my truck was doing when I first got it and before I found the mailing list (syty land hasnt been the same since either :D ). After testing and tracing circuits I started pulling fuses and looking at the contacts in the fuse panel. Sure enough one of them (dont recall which one) was FUBAR and not making good connection to the fuse which had me chasing my tail since the fuse wasnt actually blown just not making good connection in the fuse panel. Pull the fuses and check the connections where the fuses plug in to (BTW, youll need a flash light/drop light to see the terminals in the fuse panel).
maty111
i had the same poblem. i thought it was my cig lighter and tracked it down to my radio. the problem has actuallly gotten worse. ive taken out my radio. everything works fine now, fog light, dome lights, ex. it just sucks with no tunes.
matt
im having the same problem now. it happened when i plugged a car charger in the cig lighter. i checked all the fuses and ground. all good. when i open a door, the radio turns off, and my floorboard lights come on like they are supposed to, but the dome light doesnt. after i close my door the radio comes back on but it gets reset back to 12:00 and i lose all my presests. after i turn my headlights on, i try to flip the fog lights switch, my fog lights dont come on and my dome like does. then when i try to honk my horn, a weird buzzing sound comes on and the dome light comes on too, but goes off after i let go of the horn. im stumped...
crashing_sux
Blow Me?
Haven't figured mine out yet either but it did start happening right after I plugged an air pump into my cigarette lighter, which stopped working shortly after that. I wonder if it's related?
maty111
I had all those some issues and it was my radio. put a new kenwood in and I have been problem free for a while now. I only drive it at night so its got plenty of time to act up if the problem is still there.
matt
crashing_sux
Blow Me?
Well it's certainly not my radio, a thief was kind enough to help me troubleshoot the problem by stealing it. Guess it's not all bad news then :)
Jer
Don't taze me bro!
Wow... talk about timing.:tdown:
no aftermarket boost guage. but i did find the culprit. it was the horn fuse. replaced and everythings back to normal. YAY! :)
