Weird electrical issue.
Jer
Don't taze me bro!
Re: Weird electrical issue.
the_erickee said:
no aftermarket boost guage. but i did find the culprit. it was the horn fuse. replaced and everythings back to normal. YAY! :)
Where are the different fuse locations for the horn fuse and the lighter fuse and all the ones that can cause these issues? I also have a 1989 S10 Blazer that has an electrical issue where the dome lights (front and rear) stay on all the time. I'm not sure if it's a bad door pin or a bad fuse or what not.
kentuc
Jer;
On the Blazer, you may have a bad switch. Check your dash light dimmer switch to see if it`s all the way over, that turns on the dome lights also. Then check the lamp above the tailgate rear window, it has an on/off switch. If that all fails disconnect the door pin switches until the lights go out.
Next step is a short in the wiring, For that you must take a trip to Phoenix, I`ll fix it for you!!
