Lynn D. Brown
Ok Guys,
I'm hooking up the SyTy BBK Throttle Body and wondering what lines go to what ports. I see 5 ports, and the little one in the front goes to the line to the charcoal canister, right ?
It looks like the rear PCV line goes to the smaller of the two yellowish steel ports in the back of the TB. The other PCV line has to go somewhere ? So, I'm left w 3 ports on the TB - the bigger steel one at the back, and the 2 cast ports in the bottom assembly that bolts to the bottom of the TB. One of the cast ports is at the rear bottom and the other is towards the front on the bottom.
I thought maybe I remembered that one of the cast ports wasn't hooked up when I took it off, but I can blow thru both of these ports, so I guess they should be hooked to something. They would need pretty big lines.
I noticed also that the TB gasket is smaller than the TB and manifold openings all around. Has anyone cut back the gasket to fit the holes ?
TIA
TIA
