Upper/Lower trans cooler fittings
Maxtor
Which one is the send/return? I assume send is the upper upper fitting and return is the lower fitting coming out of the trans?
Thanks.
MikeRenz
not stock
The coolers flow from bottom to top. So it goes:
radiator --> bottom of tranny cooler,
top of tranny cooler --> hard metal line going to tranny
Maxtor
The stock lines and cooler are gone on #1713 - I have braided stainless line coming out of the trans going back to a huge aux cooler.
Just wondering which fitting coming out of the trans is send/return (upper or lower) without jacking up my stock sy and following the lines. I want to put my temp sender in the "send" line to get the most accurate readings.
Thanks.
B
Blake
Guest
The top line is the return line I believe. The only way to be for sure is to follow them. The one higher up on the transmission case is the return line.
George
