SchnellGhostTy
Well she is finally almost back on the road again! Although I thought I was getting close 3 months ago, but I really think I'm within a week or two from starting it. Had some free time finally last week to get a lot of little things finalized so I figured I'd share with everyone. It's been a timely and very costly build but I am trying to a build a daily driver, not another toy. So only time will tell on that aspect but its been fun, sometimes... and a lot of headaches. I come from the Euro scene and must say that even the cramped engine bays of the Euro's are easier to work on.
Now I must say that whomever worked on Ty 1066 in the past did a hack job on everything! For a slightly modded truck it looked clean, but everything I took apart was wrong, broken or just flat out half assed. I just hope who ever rebuilt the tranny did decent job, again time will tell.
The truck had code59 software, meth injection, 3" exhaust, Upgraded water to air system with stock cooler, Comp Cams, battery relocation to the trunk, C4/C5 corvette front brakes, intake and MSD on a fresh rebuilt engine and tranny w/ 3200 stall,
What I added was the following
GT3076R turbo
Eagle Rods
JE Pistons
New replacement oem crankshaft
SFI flex plate
SFI harmonic balancer
Blue printed and balanced bottom end w/ new gaskets and bearings ect...
New engine mounts
Redid the stock heads with 2.02/1.94 oversize valves and 5 angle valve job with all new hardware and ARP studs
Comp cam springs
Ac delete with non ac heater box
New 3" down pipe with wideband o2 and egt
Tial 38mm wastegate,
Tial 50mm BOV
TurboSmart Eboost 2 boost controller
Thermal wrapped down pipe, water to air box
Ceramic coated exhaust manifolds, wastegate dump and down pipe
All new sensors
All new hoses
ALL NEW HARDWARE!!! I reused less than 20 nuts and bolts that were on the truck
Rewired the entire engine bay including all the hot spots and all aftermarket interior stuff
Relocated all pumps, MSD and coolers
ABS Delete
New steering gear box
All new front suspension with bushings and all
Bilstein Shock F/R
All fluids replaced with AMSOIL products
Omari True color Boost and EGT gauges
Innovative Motorsports Wideband o2
MOMO alcantara steering wheel
MOMO leather shift knob
MOMO pedals
COBRA CF Sezuka race seat
Sabelt 3" Camlock harness
Panasonic Head unit to go with the aftermarket speakers already in it
2 10" kicker subs w/ alpine amp
I stripped all the paint from the firewall forward and repainted everything including the suspension
I know I am missing several things but I can't remember right now. Oh well, anyways really looking forward to getting her started again so I can have the rear end fixed from the 3rd day I drove it I was rear ended. Very minor but still needs to be fixed. An alignment and tuning and she should hopefully be ready to rock for the next few years, really need about 4 good years of service out of her! Let me know what you guys think. The link below has a ton of pics, naturally I lost a lot of the tear down pics so there isn't a before and after shot but it doesn't even resemble the truck I started with.
http://s133.photobucket.com/albums/q53/SchnellMotorsports/GMC%20Typhoon%20build%20pics/
GT3076R turbo
Eagle Rods
JE Pistons
SFI flex plate
New engine mounts
Comp cam springs
Tial 50mm BOV
All new sensors
All new hoses
ABS Delete
Bilstein Shock F/R
MOMO pedals
