Re: Turn-key L35 head package
It would be good to post the whole chart.
IMO , the port velocity in your turbocharged engine is a non issue, if you would want better off boost throttle response just increase the compression a bit, that will help a lot or use a smaller A/R on your turbine housing.
What is the A/R on your turbine housing?
Stock/ported heads L35's 96 & newer Vortec etc, pretty much dont flow more CFM after .500" lift.
Post your head flow chart.
217 cfm is pretty good considering it sounds like they did not open up the size of your port windows much. It most likely has a nice valve job w/proper throat angles,valve seat angles & widths, all are very important to get a cyl head to flow good.
If any of the angles,throats improperly cut, seats too wide, it will absolutely kill the airflow.
Here is Tookys Vortecs
Intake Exhaust
Lift Stock Ported Diff (CFM) Lift Stock Ported Diff (CFM)
0.050 31.3 30.6 -0.70 0.050 24.7 24.7 +0.00
0.100 62.6 61.2 -1.40 0.100 49.3 49.3 +0.00
0.150 97.0 94.9 -2.10 0.150 77.5 75.4 -2.10
0.200 131.3 128.5 -2.80 0.200 105.7 101.5 -4.20
0.250 159 154.4 -4.60 0.250 122.2 120.9 -1.30
0.300 186.6 180.3 -6.30 0.300 138.7 140.3 +1.60
0.350 202.5 197.7 -4.80 0.350 147.1 148.2 +1.10
0.400 218.5 215.2 -3.30 0.400 155.5 156.0 +0.50
0.450 227.3 224.5 -2.80 0.450 159.3 162.7 +3.40
0.500 216 227.4 +11.40 0.500 162.6 168.7 +6.10
0.550 219 219.7 +0.70 0.550 163.9 171.5 +7.60
0.600 217.2 220.8 +3.60 0.600 165.2
0.650 218.5 0.650
Avg: 184.8 188.5 +3.70 Avg: 137.5 135.7 -1.80
