Re: Turbochargers for SyTys
if you run anything other than the PTE housing, it will need adaptors or custom headers.
I have a T3 adaptor on mine (pic above) and I am happy that I did this. The 62mm and 64mm Bullseye turbos are making some good power, are cost-effective, and completely American-made.
As an example, at Nats last year I made several passes, but was having issues getting the WG solenoids to function properly. As a result, I couldnt make over 12-13# of boost. I was running a Bullseye CompR 62 (S362-variant) at about 1BAR. If you look at the compressor map for this turbo, I was barely getting the turbo to start making power, yet I trapped 114MPH and it was laying down past 600'. There was more work to be done with timing and such, but it shows the potential for this turbo. If you runt he numbers through a calculator, it calculates that my 4,000-pound truck trapping 114 was making 460ish RWHP - on a turbo that wasnt even starting to work yet.
Today, I still have the same turbo. I have switched to a Turbosmart manual boost control, set it to approximately 20#, and I have more timing in it now. I can definitely tell you that it is a much stronger turbo than I thought. Response on the street is almost immediate (TCI 300-stall converter through a TH-400 AWD) and pulls hard all the way up to 6,000 now. I am trying to sneak up on the tune, so I am slowly adding more boost. Every time I do this, it just gets faster. All this in a very streetable turbo. I have found that my 38mm wastegate is not enough to hold this reliably, so I am in the process of swapping it out to a 44mm gate.
The moral of the story is: learn about your combination, do your own research, and don't be afraid to be 'different'!
