the Sandman
My Syclone is nearing completion. We're trying to determine the best way to trigger the electric radiator fan, dual IC fans, and Meziere electric IC pump *without* using unnecessary and potentially troublesome electronics. We would just go with having all of the above on all of the time except for the high current draw when starting up the truck.
Is there a fan trigger from the FAST ECM we could use to trigger the 3 relays? If so is it delayed at all or would they all come on during cranking if the truck is already warm?
Does anyone know of a bulletproof temp sensor that could trigger the relays at say 160 degrees F water temp? I know they exist for higher temps but can't find one which triggers that low.
The electrical system has been upgraded with the physically stock-sized PowerMaster alternator. Also, Dennis has gone through all of the vehicle wiring replacing and/or upgrading the wire where appropriate, shortening, rerouting, and eliminating all non-soldered connectors. Yes, that took a good while
